I don’t have a question, but I don’t see a bug reporting section either. So here you are.
There’s a bug when viewing filled shapes that overlap, when the overlapping shape is only one node connected to itself. I don’t know, I just found the dang svg online.
That’s a curious bug. If one takes any other shape and moves it outside, it fills. Moving it back inside, it empties. The two anomalies will not fill. Changing to a new layer set to fill: nothing. I’ll bet that’s going to be a challenge.
Thank you for drawing our attention to this. I see what you describe while running on Mac and will generate a report for this. Which OS are you using here?
I noticed this recently too. It was some CorelDraw clipart I was using. If I remember correctly I just added an extra node to make it display properly. Obviously this isn’t ideal and not very practical if you’ve got a lot of these single node shapes in a design so it would be good can be fixed.
