1/16" Basswood 16" x16"
Anyone know where one can purchase 1/16 inch Basswood [or whatever wood] that is 16" x 16"? I found one on Amazon, but it’s actually closer to 2.4+ millimeters not 1/16 of an inch. I can easily find 12" x 12" x 1/16" that’s actually 1/16 of an inch [1.56-1.57mm], but I can’t find anything that is 16" x 16" 1/16". Any help would be greatly appreciated, links also. Thank you. North Carolina, USA
Hey @vtskiman
Don’t forget LightBurn has customers all over the world. I myself am in the United Kingdom. Help your fellow forum visitors out by letting people know which country and area you are in?
North Carolina, USA
Try Here.
And i’ve found that most places where you buy Baltic Birch Plywood the dimension varies a bit from the published dimensions. Just like all lumber. If you buy a 2 x 4 its not really 2 x 4
https://ocoochhardwoods.com/
I’ve purchased wood from Ocooch before and they are really good and the sizes they specify are true sizes unless they mention nominal. Baltic Birch plywood, regardless of where it is purchased is nominal size, even at Ocooch and they state it on their web site.
