1.2.03 update bug with fill layers
“Fill all shapes at once” not working after update. It is trying to fill groups together.
Can you show an example of what you mean? Make sure you don’t have “Order by Groups” as the first option in your Optimization Settings window.
The way it worked before, the “Fill all shapes at once” setting took precedence, but that confused basically everyone, so we changed it to make the Optimization Settings happen first, then the filling is done with whatever groups the optimizer comes up with, so you might see a change in behavior based on the settings you use.
Sure as you can see in this example i put my name close to the logo to where it is most efficient to make one pass and do both the logo and my name at the same time. In the preview window you can see that it does the logo first then goes back to add the name.
I am aware for now i can group the two and get the result I want, I was more trying to give notice of the issue and hope it helps development. :slight_smile:
sorry for some reason i missed the second part of your message, this is my optimization settings
Capture6
So, because you have ‘By Group’ in there, if the shapes are not in the same parent group they will be processed independently. That is intended. (“not grouped” is considered the same group)
Ok yeah, deleting order by group solved the issue, thank you so much!
