1.4.00 doesn't resolve the pause bug
Am I the only one using pause when I need to leave the room ?
I already submitted this bug with the previous version, but it’s still here.
When I click on “pause” its label does not switch to “resume” (but the request for pausing has been recorded, so the machine will pause eventually).
When I click a second time on “pause” its label now switches to “resume” when in fact the pause has been released.
This is a bug and can get very confusing.
The communication is buffered.
The firmware in the laser engraver handles how it responds to a Pause command.
I will track down your submission and the status of the bug report.
While I track it down, I’d like to confirm the model number and firmware version of your Ortur engraver.
In LightBurn with your Ortur connected, enter the following request for a report:
$i
followed by enter.
Please copy and paste the short report into a reply here so that I’ll know exactly which firmware version you are working with.
Hi John,
Thank you for your answer, here is the result or the $i commande :
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:210]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230223]
[SN:DD33366A3A94BEADE0D0AF8E1BC8BBA0]
[VER:1.1f.20220325:]
[OPT:VNZHTS+W,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:84:F7:03:F7:29:FC]
[IP:192.168.2.21]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Also running Lightburn 1.4.00 via USB on a 2013 iMac running MacOS 10.15.7 Catalina.
I know there is a buffer, which is the reason why sometimes the acual pause do not happen immediately (I experienced latencies of over 30’ when burning long lines).
What I am reporting here is unrelated to this : when I click on “pause” the label on the button NEVER changes to “resume” unless I click on pause again. On this second click the label changes to “resume” but the burn is also resumed.
Have a nice day nevertheless :slight_smile:
We have this in discussion now and will be testing shortly.
We’ll report back when we know more.
