Every since Lightburn 1.4.05 updated, I have faced continual issues trying to burn anything. The time it takes to burn is much longer than before, all on my layer presets settings have changed, offset fill now takes a lot longer, today I wasted a cutting board due to the burn area was very unstable leaving high and low spots, where it would flawlessly cut 7mm luan, its hit and miss if it will cut all the way through. Usuaally the backside shows like it skipped around. last night it was 3.5 hours to burn and cut 4-7mm coasters.
Thanks for your help
This is almost certainly not the case.
Make sure you’re working in the units that you think you’re working in. If you are expecting mm/min check that you’re not using mm/s or something else. Change this in Edit->Settings if indeed incorrect.
You can also go to 'File > Load Prefs Backup ’ to restore your settings to a previous time if they have inadvertently changed.
