Hello guys, any ideas why my inward offset shape does not work? It works with both (inward and outwards) and also when I select outwards only, but in this case it does both inwards and outwards (same as when I select both)
Thanks in advance!
If we could see what āthis caseā looks like, we could be far more helpful.
With that in mind: If the shape is not closed, then it has no āinsideā and the offset will apply to both sides of the lines forming its perimeter.
If Edit ā Select Open Shapes
selects what you think should be a closed shape, thatās the problem.
You nailed it! Thanks so much, I verrified and the shape was indeed open (even though I thought I closed it with edit nodes. I didnāy know that " If the shape is not closed, then it has no āinsideā and the offset will apply to both sides of the lines forming its perimeter". I am a bit ashamed, and learned something the hard way. Thanks again Ed!
Donāt feel bad: weāve all been there & done that ā¦
To assist others searching for similar, I have marked the reply from Ed as āSolvedā. In the future, please do mark the solution once provided. It helps us all.
So sorry, i didnāt know I could mark it as problem solved. Iāll certainly do it next time! Another one that I learned!
All good friend.
