1.7 beta and atomstack m4
Hello… I downloaded the beta 1.7 and purchased the galvo license to use the atomstack m4. It worked originally on the beta 1.7 but it would start to laser soon as I put any design on the work area so I looked at the lightburn forums and found the solution to change start framing to none. I did that but now my laser doesn’t mark anything. The red dot will show very faintly then when I hit start it frames for a couple of seconds then goes back to my square for framing. . I’m not sure what info you need exactly so I’ll just start with does and power I tried from 80-300mm/s and 100 power. I imported my parameters when setting up that’s when it worked until I had to change the framing to stop from starting immediately.
Kinda of the same here, but its not beta, it just did regular update, my license has the Gcode and Galvo support already. M4 also. Having trouble doing the preview SeaCad had for alignment.
