100 X 100 mm square engraves as 79 X 79
Configure axes option is not there in Device settings. I can’t see where else I could modify the scaling.
I think galvo 1 and galvo 2 scales are the scales. I changed them to 100 and it seemed to get real close but not exact.
I can live with that.
Is your work area really 220x220? That is an unusual size. Not unheard of, but not common.
I actually don’t think that’s a good idea… it would also help to know what F lens you have.
@Albroswift … I think you are right about the working area…
The lens correction file determines this… along with the size of the scan field. I think if you change the percentage, you change where the lens correction is applied…
If you machine is setup by the manufacturer, it should have a file to import into Lightburn when you do the device setup…
Did you import the file then?
Couldn’t figure out actual workspace from the laser machine… that covers the need for objects we generally engrave… Is there a way to figure out the actual limits of the machine
The galvo doesn’t change, coverage is based on the lens.
