This is something that really bothers me. It’s easy to solve by stretching the offending piece into the large rectangle, but I want to know why this happens.
I have one large and several small rectangles that I need to weld to form a legged rectangle to use as a the floor for a box-
All the small rectangles have been positioned using alignment shorcuts, and the sizes are the same for all of them. I select all the pieces, hit WELD and most of them weld correctly into the large rectangle. However, there is one (top left) that just doesn’t and a line remains between the pieces. It seems like instead of welding, they just grouped.
If I delete the top center rectangle, top left it welds just fine. I thought this could be a limitation on how many pieces can be welded at a time, but quickly discarded that idea.
I atached file mystery.lbrn2 in case someone want to try and weld the parts.
