What were you using before, and on what kind of controller? Was the updated firmware provided by the vendor, compiled by you, gotten somewhere else, or …?
I’m using a Arduino nano dual y cnc controller with grbl 1.1h. Just changed a 3.5w to 15w laser.
I must assume that the 3 pin 12v pwm 15w laser is not getting enough power. 12v 5 amp input is what I am using…
Just the strangest thing. Replaced 15w laser with 3w laser everything runs correct.
15w laser turns on and don’t burn. Must be a power issue I am missing…
