You can highlight a portion of my response and click on ‘Quote’, it will place the question in highlights like this
The ‘laser set’ is for the ‘pulse’ button. If it’s continuous, the laser stays on until you release the button.
Otherwise you set it for the duration of the pulse.
Doesn’t matter what ‘laser set’ is, the pulse power or pwm % power is set via the Maximum button on the controller.
These controllers operate a little different from the console than from a layer.
Power/speed is set on the cut/layer.
When engraving or cutting, the machine can’t stop and go the other direction instantly. You can set a layer for a maximum and minimum power range. As the machine slows to change direction it will adjust the power with this range.
Don’t know, that’s why I’m asking… You have a laser, what kind of a dot would you expect?
You are on it with the ‘looks like a crisp dot’ which is what you want. How big is this ‘dot’?
I think you’re going too fast and the end result will be confusion between us both. Don’t get in a hurry you will just break something.
We’ll get you going… hang in there…
Most of the stuff you would need to modify is available via Llightburn Gui interface ‘Edit → Machine Settings’. Don’t forget to save the current configuration as a ‘factory fresh’ configuration file. I have multiple configurations depending on what I’m doing. All of this can be done via the gui.
I think you would feel better if we got it to cut, what do you think?
That means some details about your setup and how you ensure the vertical alignment is on. Most of these Chinese heads, it’s difficult to determine alignment as you can’t get in there.
One way to tell vertical alignment is to remove the lens so you have a tube with no lens. A piece of paper or something you can mark with low power. I sometimes use a piece of plywood.
Raise the bed till the paper or whatever is touching the tube.
If possible use a pencil and draw around the tube. This helps to determine if it’s centered. Some people have put modeling clay on the table and the tube leaves an imprint…
Fire the machine for a short duration, just enough to make a brown mark.
Now lower the bed 4 or 5 inches. Is the mark in the center and looking OK?
Fire the laser again. The two marks should be in the same place… or very close.
Sometimes you have to pulse if multiple times to see the spot, if the duration is short.
