2.1.03 application freeze / lockup when preview with offset fill - Win 11, Longer B1
How long does LightBurn lock up for? Does the preview ever load?
In general, Offset Fill takes quite a bit of power, and is primarily intended for ‘donut’ shapes or frames that have a filled border and a lot of empty space inside the shape.
There is also a warning about this in our documentation (below)
Offset Fill Computation Time
Offset Fill is very computationally expensive, and the more complex the design, or the smaller the Line Interval set, the more potential there is for the computation to cause LightBurn to hang. Sometimes graphics with stray nodes or unusual paths can confuse the calculation interminably.
If you enable ‘Cut Selected Graphics’ in your laser window and only select a portion of your design, does the preview load?
Well this is what i figured out. I had a bad font… not sure how or why, but i reduced my image to each component, and when i did i discovered the “teach” in the design is where it failed
so i deleted that element and re-created it, with the same font, and it worked. not sure why, but i did get it to work.
Glad I am not the only one this happens to!
