2.1.04 Camera Setup
I feel like a beginner trying to figure out how to calibrate and align the camera.Call me stupid, but I cannot find clear instructions to do these tasks. You may think you’ve improved the camera setup but in my opinion the method used in 1.7 was a piece of cake.
Dale
The V 2.1 doc for the Camera window:
Lens calibration step-by-step:
Camera alignment step-by-step:
However, V 2.2 has another way of getting it done, so you may want to install & try the most recent pre-release version:
Thanks for all of the information, Ed
. But, I still have a problems. I’ve attached 2 screenshots. The first one was from last night when I was going out of my mind. Note bottom right of the screen, no selections shown . This morning, “next” showed up in lower left, and I was able to calibrate, 10 locations, all 100%.
The second one, is after calibration. when I click on update overlay, the pattern does not show on the work space. I just tried to align, and the first screen, again shows no options in the lower right corner.
Is this update buggy?
Dale
Perhaps, I should go back to 2.0 and reinstall2.1? Maybe the file is corrupt?
You have opacity set to 0%
Move the slider to the right.
I move to far right is black, moving to mid point, it’s Grey. It doesn’t show the camera overlay.
Again, I’m starting to think that the download was somehow corrupt. However, I did manage to calibrate. Then, when attempting to align, after selecting the pattern, their was no “skip, back, continue, or cancel” buttons. I had the same issue with the calibration. First, the buttons weren’t there. Then after I shut everything down and restarted the buttons were magically there.
Probably, but not in the sense you mean.
The screenshot suggests the monitor resolution is 1366×768, well below the minimum 1024 vertical pixels, which means it can’t display everything LightBurn has to show:
Unfortunately, there’s no fix other than getting a bigger monitor.
I guess I need a new laptop
Or an external HD (1920×1080) monitor, which seem to be under $100 these days.
I’ll put in a vote for a QHD display (2560×1440): get one of those and your eyes will dance for joy. :grin:
Or a 4K one set to QHD.
A column driver in my six year old QHD monitor failed, painting a bright red stripe down the the display. I replaced it with a 32 inch UHD (3841×2160) and it is wonderful; cost about the same as the old one, too.
The QHD remote desktop from the mini-PC running Windows on the laser fits neatly in the middle of the screen:
My eyeballs are lovin’ it!
Is that an airplane cockpit? Were you a pilot? A friend of mine flew intercontinental for American. He’s going to love this!
With my current laptop, the text on my screen is tiny. Which update caused this?
Thanks for your help
Dale
It’s the cockpit of XB-70A #1 from a picture like this:
That’s a low-res version unearthed by a casual search, but the one I found (long ago) is 3030×2606 and should be out there somewhere.
I set the desktop lock screens & backgrounds on all the PCs to different images on the file server as an obvious indication should the LAN or server wake up dead.
Tweak these settings:
However, a tiny screen has no headroom between “too small” and “doesn’t fit”.
If I had that on my monitor, I would never get any work done! :rofl:
[digression]
That one’s kinda personal. Long long ago, I was on a biz trip (!) to Wright-Pat and stood under a wing of that beast, watching rain drip through the joints. Standing aft, I could just imagine engineers muttering over their slipsticks “OK, looks like it’ll need 5.4 of those engines, so let’s call it six.”
Much later I got to crawl through the Smithsonian aircraft warehouses at Silver Hill and unknowingly stood up in what turned out to be the forward bomb bay of the Enola Gay …
[/digression]
Hey Ed,
So, I bought a new laptop 1920 X 1200 resolution, I’m good to go with release 2.1.
Thank you for your help!
Dale
You’ll be amazed at what you can see in there! :grin:
