I’ve completed the lens calibration, no problem. Next alignment. I completed the engraving engraving the test pattern, which did not show on my work surface. “Update Overlay” is grey, and can’t be selected. I cannot complete alignment. I’ve tried everything I can think of, I’m stuck, I need help, please.
As described above, you’ll need to have a suitable large piece of material, appropriate cut settings for a crisp, dark mark, and your camera securely mounted in the location you want to use it from.
When the camera can recognize the patterns engraved on the surface, then you can proceed.
Note:
Do not move the pattern after you burn it, or you will need to burn a new alignment pattern.
