Royce
(Paul Arnold)
April 3, 2025, 9:09am
1
Hi,
I imported an image into LB and dupplicated it. For both layers, I set Number of passes: 1
However, LB does 2 passes on both layers, resulting in 4 passes instead of 2.
The layer settings are identical except the scan angle (0° → 90°).
What am I missing here?
Thanks!
jkwilborn
(Jack Wilborn)
April 3, 2025, 5:47pm
2
Do you usually run using Pass-Through ? The source is not modified but sent directly through to the laser.
I’d suggest you disable it and run another test.
Royce
(Paul Arnold)
April 4, 2025, 12:37pm
3
I actually do because I have the image processed beforhand
Diabling pass-through as a test didn’t yield a positive result tho, still 4 passes in total
jkwilborn
(Jack Wilborn)
April 4, 2025, 2:19pm
4
Ok, the artwork is resampled if this isn’t enabled.
Do you have the global pass count at 1 or two? Does it show two passes in the preview?
system
(system)
Closed
May 4, 2025, 2:20pm
5
