Hello, I need help with the pass count I always leave it at 1 pass but everytime does 2 passes is there something I could do to disable the multiple passes? help me please.
thank you
For sure is not a problem of multiple pass, try this, select all you have in work area then press no matter which arrow key, you will notice that you have a duplicate job in the working area.
so you solved? was this the “issue”?
I restarted my laptop and my machine and it worked just fine.
Thank you for your help.
