I am using LightBurn Pro 2.1.03 with a JCZ/EZCAD2 galvo controller.
I am calibrating a 300 mm F-theta lens using the Galvo Lens Calibration tool. The uncorrected calibration matrix engraves in the expected locations and is generally square, although visibly bulged. My measured center-to-edge values are approximately 149–159 mm.
After completing the calibration, centered nested squares no longer engrave concentrically. They are shifted and appear compressed toward the upper-right corner of the scan field as well as bulge on the engravings.
I have repeated the calibration carefully two or three times with similar results. When I reinstall the 110, 150 and 220 mm lens and use their calibrated profiles, the shapes remain centered and show no comparable skew as the 300mm profile.
Has anyone seen this? I’ve not attempted a manual method yet, I’d like to avoid if possible TIA
