4.2 watt won't burn
cnc will go through the motions created in Lightburn but no burn not even test burn - test burn is set and $32=1 is set - what am i missing - I’m new to this - thanks in advance
Not exactly sure what your wiring is but you need to
a) feed the laser with clean power (i assume 12v)
b) feed the laser with PWM signal, which is where the $30 $31 and $32 comes at
could you review the wiring and let us know how you plugged all in?
Can you tell me what the setting is for $30 ?
