I’m a bit confused about the cameras and the differences between them.
When I look at the 4K-N camera page it says:
A middle ground between our high-quality 8MP-wide cameras and the 5MP cameras, these are the same physical size as the 5MP, with a higher resolution sensor, but comparable image quality, and with a 4:3 aspect ratio.
Does that mean that the 4K-W camera has higher image quality than the 4K-N?
My bed is 900x600 so the 4:3 aspect ratio of the 4K-N camera is a better match. My camera would be 950mm above the surface (centered on the cutting area) so I could use 4K-W with 95 degree lens or 4K-N with 75 degree lens.
Which one will give me better results?
