About LB fire safety notes
describes CO2 vs dry extinguishers as the options.
Dry ABC (powder) shouldn’t be used, it could total the machine with powder.
CO2 is an option, but not a good one. CO2 is in theory cheaper fills, but it’s a bulky, heavy, extremely high pressure tank, an expensive initial outlay and must get expensive testing regularly. there is a case where it’s more cost-effective if discharged and recharged quite often, but that’s not us
What you want is Halotron extinguishers. $275 2.5lb is physically small but halon is potent and 2.5lb is plenty for any fire an extinguisher could ever put out. zero residue, no cleanup, no damage- not from the extinguisher
also, i’d emphasize the value of a spray bottle of water. it’s got a passing mention. truth is, most fires are caught at a level where this works, no real cleanup issue, no refill cost. probably 95% of the time a water spray bottle would work and is the better option by far. second, a 2.5lb Halotron if that doesn’t work. if the Halotron doesn’t work, run. Well, if you find a big dry ABC on the way out, your laser is probably already a total loss so that’s technically a good option now.
Thanks Danny, I hadn’t heard of Halotron.
However, when I looked it up I saw that it may not be the cleanest for the environment or for health?[1](although neither is a burning machine) . I understand there is a newer formulation ‘Halotron BrX’ which is better but prohibitively expensive and only really sold for use on aircraft.
One fire safety system not in the notes but that I would highly recommend (to use in addition to a normal handheld extinguisher for extra protection) is the BlazeCut automatic suppression system.
  1. it uses HCFC-123 (hydrochlorofluorocarbon) which is being phased out, see the Safety Data Sheet ↩︎
Halotron extinguishers up to 5.5 pound = 2.5 kg have only BC ratings: liquids and electrical fires. Bigger ones (11 pound = 10 kg and up) have the ABC rating you’d want for burning solids in your laser.
That said, any extinguisher is better than none, although that’s not the only CO₂ bottle within reach around here. :grin:
Edit: The curative powers of a water spray bottle cannot be overstated!
Ever hear of halon? One of the first places I worked had a halon systems in each computer room. It was found to have some issues, such as not ozone friendly. It was replace with halotron.
Check it with AI if you’re curious.
Retired and I don’t have deep pockets, so haotron (and halon) are above my spending limit.
I have a 5lb co2 device. Follows me around to any of the lasers.
:grinning_cat:
Yeah, A.I. always has the most accurate facts.
Halon is an oxygen displacement gas. Fatal if you are in the room with it.
Halotron is a florocarbon, and not so dangereous (just learned this today). Still needs caution.
It definitely displaces oxygen. But it’s not supposed to be fatal that’s why we used it. The idea is you can invoke the halon and have time to get out of the computer room, unlike other gases like co2.
Like most things, how dangerous it is depends on many condition.
AI sometimes has questionable results. However some items, like digging though manuals, seems to work well. It also gives you a link to where it found it.
One time, it stated to use your voltmeter to check the lps on a dc excited tube… lol.
:grinning_cat:
Well, for sufficiently large values of voltmeter … :face_with_head_bandage:
All I can think of is …
:high_voltage:
:grinning_cat:
Also beware of using halogen on lithium battery related fires; hydrogen fluoride is not your friend!
