Acrylic cutting help?
How I can cutting acrylic transparent my laser two trees tts-55 40w how i can adjusted my settings
Nothing you can do will allow you to cut through clear acrylic with a blue diode laser. The material is virtually transparent to the wavelength of light.
You might be able to do solid black acrylic with two passes and air assist, I was able to with my 40W. Clear acrylic, though, absolutely not.
You can adjust your settings in the cut settings editor.
