Activation Issue
I have had this software since 11/15/21 and when I tried to use Lightburn today it told me that I needed to enter the Activation Code. I entered the code that I originally had gotten and a window came up that said “Activation limit has been reached”. I do have this on two computers but it has been on both computers since I bought the software. I sent an email to support but I have not heard back from them yet. I was going to see if anyone else had this problem and had an answer. Thanks!
In the upper right of the forum window is a link to the license portal…
That can happen if “enough” changes on your computer that it fools the license system into thinking it’s a different machine. Usually this is a hardware change, but significant OS updates can cause it too.
If you’re comfortable using the license portal you can remove the computer from there, then re-enter the key, or you can email support (include your license key) and we’ll help you there.
Thank you for your help! Support emailed almost the same time you replied so hopefully between you two I will get this resolved.
