Actual etch pattern is a few mm out with preview frame
Hi. the etch I am getting is a few mm out from the preview. Is there a way of rectifying this?
Any chance you have
Pointer Offset turned on?
What does this mean?
Picture and screenshots will help us see what you’re seeing.
In general, misalignments between the LightBurn Preview image and the results on the material are due to mechanical problems: the laser head does not go to the commanded position.
However, if it’s this machine, then there’s a bunch of calibration you must perform:
If you’ve done all that and reviewed the lens corrections, other folks with more galvo experience may show up to help …
