I use my laser for engraving on pens, and I made this jig where I add 12 pens at a time. Right now I manually write all 12 names when I start a new project. Is there a way to automate this process?
I remember from my old China laser days using Corel that you could write something in an box and then it could repeat the opreation multiple times on the laser.
I was hoping to have one field where I added the text, and then the remaining fields were automatically updated with the exact same name.
Variable text seems to be a bit different.
/Peter
When copying a text shape using Grid Array, Circle Array, or Copy along Path, LightBurn can automatically advance the ‘Offset’ value on your variable text objects for you. In this way you can quickly create full sheets of items containing serial numbers or CSV file references.
The ‘Virtual Array’ feature in 1.0 would do this too - You could create a virtual array of the name, then changing the master would change all the copies automatically.
