Adding files to Library
Is there a function I can use to add my craft files to the library, which keeps the settings I use to create that craft?
By settings do you mean the Cut settings? If so, no. You’d be better off saving the Projects files for the designs that you want. Or setup one Project with the cut settings for the types of design you want to use, then use the art library to import into that project.
