Hello!! If I had already burned a picture can I go back into Lightburn, add text and just burn the text into the object?
Thank you!!
Thank you!!
The only problem you’ll have is getting it lined up to where you want it,(shouldn’t be hard) unless you want to redo the whole thing and add the text as part of the redo.
You can add the text, and then select “Cut Selected Graphics” to burn just the text. As Kris1 mentioned, you will have to make sure it properly aligns.
