Adding new layers
hey again.
Im trying to create some lines, each on different layer, but cant find how to do that. i got all lines on same layer. thanks.
You just select the part of the drawing you want on a new layer and select a new layer / color from the bottom line.
not exactly understand - how to select another line on New layer? there only one layer it shows…
oh, lol. my laptop screen is 1368x768 and this colors, at bottom, sometimes hided. thanks, m8!
If that’s the case for your resolution, I suggest you put all necessary windows into a single pane on the right instead of the 2 stacked panes that are there by default. This will help you better manage your vertical resolution.
