Adjust focus does not match the settings
I have a new to me Monport MP-570 - which seems to be an Om-tech clone with a ruida controller.
I went to use the auto focus feature of the machine, and the bed adjusts hits the sensor and backs off about 20 mm. this should be 10 mm, the settings in LB say 10
where is the setting to adjust this?
The overall distance is the sum of Home Offset and Focus Distance, so I betcha the former is set absurdly high. Maybe a typo from “1 mm” that could happen to anyone? :grin:
It would be helpful to keep all this under the original topic:
Hi @sr3051
Looking at your earlier screenshots, you have a Home Offset of 15 mm for Z and 24 mm for U.
As @ednisley explains, the Focus Distance isn’t the only value determining how far the bed retracts.
Can you confirm whether your machine uses the Z or U axis to control the bed?
It’s also worth checking whether commanding a 10 mm downward movement actually moves the bed 10 mm. This will help rule out an axis calibration problem.
Please save a backup using Laser Tools → Machine Settings → Save to File before changing any controller settings.
