Adjusting X & Y Without Distortion
I don’t know if this is in the realm of LB or some other program.
I have some vector file images that I’m trying to make it fit a certain area by widening or narrowing the image, but doing so distorts the image.
Is there some way to do it without the distortion?
Thank you.
If you’re dragging the corner handles of a selection, hold down the Shift key:
If you’re using the Numeric Edits toolbar, make sure the Lock icon is “locked”:
Thank you.
To change the width or height without distortion, you must accept that you will lose part of the image depending on which direction you stretch the image. In Lightburn, keep the aspect ratio locked and adjust the width OR height as needed, then trim off the excess.
I was hoping that wasn’t it, but thanks.
