Nothing Crazy, just trying to figure out how to use a Tapered Ball Mill to V-carve. just wondering if anyone has any advice?
my understanding is it should be straightforward. the software should be able to calculate based on the tip geometry leading to filleted insides. but how does that work in practice?
you set it up the same as u would for a v carve , for the couple of trials that i have done in only MM not actual cutting is it looks more like a profile cut due to the small angle of the tool
Makes sense. shallow angle of the tool will kinda flatten the chamfer effect. which, for my current project isn’t exactly undesirable. but maybe it would make for good roughing passes to later follow with an actual sharp v-bit?
For the 1.0 release we have the ability to use an end mill to clear material for a V carve.
You can also use a tapered end mill (flat tip) or a tapered ball mill (round tip), and all of them work as intended. You don’t need to do anything special for those to work, but check the preview first - I know there were some bugs fixed in V-carving to do with the extra bit types, and not sure if those made it to the 0.9 full release.
Was just experiementing with MIllMage on our makerspace generic 1325 unit (LinuxCNC driver). After a few gcode configurations the only thing I was missing was a start position in the project material settings and the rest machining (hopefully you’ll set that up to allow for multiple clearing endmills for a vcarve).
I know its early, but I hope you will consider some sort of makerspace version/licensing. I know thats helped us with keeping people from pirating lightburn over in our Laser shop.
