we have an AEON MIRA and we have an issue with the calibration. the Z-axis runs in the correct directions for up and down when manually moving the machine when calibrating it moves correctly up to the mechanical calibrator however after touching off the final offset moves up and drives it’self into the head of the laser. it seems like the offset polarity is wrong however we can’t find how to change it.
I haven’t ever done this, so I’m not 100% sure what you’re referring to, but I’m assuming that would be in Edit > Machine Settings, in the vendor settings area at the bottom (folded up by default - you’ll have to expand it).
