Affinity 2 DXF file import into Art Library
Hi,
Does anyone use Affinity 2 Designer, I can’t get a DXF file I’ve made using it to import into an art library it doesn’t crash just nothing happens and nothing appears. The file opens fine in other programs Any ideas?
Thanks
Hi Jon
Any chance you could send an example of a DXF file to support@lightburnsoftware.com.
That way the dev team could take a look.
As well as sending a DXF to LB support would you mind attaching your Affinity Designer file here so we can have a play with it? You might need to append a “.txt” to the file name (eg. “myfile.afdesign.txt”) to allow the file to be attached.
