After stopping job lightburn is loosing the laser position
Hey there,
I am new here, so hope this is the right place.
When I do stop (not pause) any job, lightburn looses the position so I need to do the homing every time.
Does anybody have an idea?
The console shows me the following error:
" ALARM:3
In Bewegung zurücksetzen. Grbl kann die Position nicht garantieren. Verlorene Schritte sind wahrscheinlich. Die Rückkehr zur Ausgangsposition wird dringend empfohlen." ALARM:3
Reset in motion. Grbl cannot guarantee the position. Lost steps are likely. Returning to the starting position is strongly recommended.
I appreciate every idea and help :slight_smile:
I have got an Ikier K1 pro max
best regards
Don’t push stop if you want to preserve position.
You may be able to work around this by first pushing pause, then stop.
hey, thanks for this hint. But it doesn´t work… it is realy strange.
What do you mean it doesn’t work? What happens instead?
And to confirm, during a running job you push pause, after it’s paused you then push stop. You’re saying that doesn’t return control and retain position?
If it doesn’t work then it’s possibly a firmware issue. Take a screenshot of what you’re seeing.
