After update when starting jogs machine goes in the Y- direction till it crashes
Hey everyone, at my wits end here and hoping someone can help. I have a xpro v5 controller and a neje laser. After I updated to the newest version of lightburn my machine moves only in the y- direction when i start a job and moves that direction till it crashes to the side. This never happened before, is anyone else having this problem
This is almost certainly not going to be related to the update.
A few questions:
  1. Do jogging controls work as expected?
  2. Does your machine have homing switches? If so, does the machine home properly? To what corner does your machine home?
Can you run these commands in Console and return all output?
$H
$I
Thanks for the quick response. Yes jogging controls work as they should
$H- it says homing cycle is not enabled in your GRBL settings
$I -
[VER:1.3a.20201022:]
[OPT:MPHBSW#]
[MSG:Using machine:CNC_xPRO_V5_XYYZ]
[MSG:Mode=AP:SSDI=CNC_xPRO_V5:IP=192.168.0.1:MAC=8C-4B-14-F7-3B-F1]
[MSG:No BT]
$0=4
$1=255
$2=0
$3=0
$4=0
$5=0
$6=1
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=3
$24=200.000
$25=2000.000
$26=250.000
$27=2.500
$30=1000.000
$31=100.000
$32=1
$N1=
$N0=
$100=200.000
$101=200.00
$102=200.000
$103=200.000
$104=100.000
$105=100.000
$110=2500.000
$111=2500.000
$112=2500.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=100.000
$121=100.000
$122=100.000
$123=200.000
$124=200.000
$125=200.000
$130=300.000
$131=300.000
$132=300.000
$133=300.000
$134=300.000
$135=300.000
[G54:-2.215,-276.360,-18.287]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
<Idle|WPos:2.010,250.675,18.287|FS:0,0|Pn:PXYZ|WCO:-2.215,-276.360,-18.287>
I believe this is all the info
do you have any idea I have still been trying but am totally stumped
Did you create this offset on purpose? If not, remove it by running this in Console:
G10 L2 P1 X0 Y0 Z0
Power cycle and then retest.
No I had not that just showed up after the update I wonder why… I will give it a try when I get the shop later today thank you very much for the help
Thank you so much that seemed to do the trick. I hadnt set that offset so im not sure why it came up but so far so good thanks again
