My Orian Tech 50W laser has a straigt thru air assist nozzle so I cannot adjust the air flow. I have looked online and cannot locate anything that I believe would work. Can someone tell me where to buy a replacement nozzle or connector that has the ability to adjust the airflow?
There’s a bunch on amazon. This is a bunch of connectors. This is a bunch of valves.
This is my machine. I use the valve connected to the “Wind” output. So I bypass the valve and get low air pressure, and when I select ‘Air Assist’ from the layer I get full air pressure.
Any of the valves will work, whatever blows your skirt up.
Looks like we have the same machine
Good luck
