Air assist - Delay Relay
I agree.
The dial is on E mode. Double checked that just now to be sure.
Going to follow the wires again.
I GOT IT WORKING!!
:tada: :tada: :confetti_ball: :tada: :confetti_ball:
I am not sure what I did wrong… but I took all the wires out and put them back together… and it worked.
I think I switched the polarity somewhere.
But thank you @Stroonzo and @rojhan and @Stan and @Rud
One happy guy here now :slight_smile:
Something I thought about today, you should probably put a flyback / snubber diode on the relay coil (maybe like a 1N4007) to suppress the inductance voltage from slapping your controller around.
Illustrated here in a short video I made:
Some relays have this built in. Won’t hurt to add a second one, but no reason for more wiring if not needed. :slight_smile:
Well, as you can see in that video that relay doesn’t have it built in (and that’s the exact same relay I used).
Hmm did you notice anything strange in its behavior before you thought of this diode solution?
I did see the diode as well in the ultimate air assist drawing in 2 places.
