Can I please double check with you guys that my new AirAssist settings for M106/7 commands should work with these smoothie settings? Thank you.
#Switch modules
#See http://smoothieware.org/switch
#Switch module for fan control
switch.fan.enable true # Enable this module
switch.AirAssist.enable true
switch.AirAssist.output_pin 2.7 #EH0 24V
switch.AirAssist.input_on_command M106 #Calling this command sets the switch ON
switch.AirAssist.input_off_command M107 #Calling this command sets the switch OFF
Notes:
- Pin 2.7 is my smoothieboard heater HE0 which is free for use.
- HE0 will drive a 24VDC > 220VAC external SSR switch.
Thank you.
