Newbie here. Ran a few things no problem. Now I get Alarm:15 on or near line 0: intermittently. Sometimes 2 inches in, sometimes half way through.speed and power make no difference. Generic roomark 10w laser. Tried rebooting, new cables, reinstalling software. What the heck? I can’t be first to have this. Google was no help .TIA
Help us see what you’re seeing. Please post a screenshot of your entire Lightburn screen with your project loaded and the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon).
Thanks, to do all that would require many screenshots of many projects. The error will happen at any time on any project, regardless of power or speed. nothing is consistent except for " Alarm15 "
Then it’s most likely your communication method that’s failing. If you use USB, try another cable, port or both. Make sure it’s a high quality cable.
Thank You all. Problem solved. I reached out to Lightbburn and they provided a “generic 10w” profile for my laser. night and day on test burns. threw an error first try but running fine now. Cheers
What profile were you using?
