bturner
(Brandon Turner)
January 15, 2022, 11:25pm
1
I have not been having any issues with my machine. Today I hooked up the rotary attachment for the first time and when I switched back, I cannot move my laser to a specific point and am getting the error:
G code motion target exceeds machine travel
My machine is an Ortur laser master 2 pro
berainlb
(PY)
January 15, 2022, 11:42pm
2
Easy fix is probably to just reset your GRBL config by running this in Console:
$RST=*
If you want to find out what’s going on then issue these commands instead and send output here:
$I
Bluesssman
(Gary Martin)
January 16, 2022, 9:32pm
3
I am having the same problem. Where do I go in the program to rest GRBL? Not sure what Console is.
Thank you!
berainlb
(PY)
January 16, 2022, 9:37pm
4
Look for the highlighted area. If the window is not there make sure it’s enabled under Window menu.
berainlb
(PY)
January 16, 2022, 9:43pm
6
Just reading your profile. I do not know if $RST=* is considered “safe” on NEJE. It’s meant to go to default values but it’s possible that you don’t want default for NEJE. It may be fine but I’m just not aware.
Bluesssman
(Gary Martin)
January 16, 2022, 10:41pm
7
It seemed to work, except now after homing, when I try to go to origin the laser only travels about 1/3 of the way then stops.
berainlb
(PY)
January 16, 2022, 10:52pm
8
Can you explain further please?
Does the homing itself complete as normal?
When you go to origin does it travel normally?
I suspect the reset may have changed your frame dimensions.
What is the position at home location?
What are the expected dimensions for your laser?
Can you run this in console please and return results:
Bluesssman
(Gary Martin)
January 16, 2022, 10:55pm
9
Homes itself normally.
Going to origin it travels normal.
$0=10
$1=25
$2=0
$3=3
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=250.000
$25=1000.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=4000.000
$111=4000.000
$112=4000.000
$120=200.000
$121=200.000
$122=200.000
$130=150.000
$131=150.000
$132=150.000
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|MPos:0.000,150.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:02
ok
$0=10
$1=25
$2=0
$3=3
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=250.000
$25=1000.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=4000.000
$111=4000.000
$112=4000.000
$120=200.000
$121=200.000
$122=200.000
$130=150.000
$131=150.000
$132=150.000
ok
[TLO:0.000]
ok
ok
berainlb
(PY)
January 16, 2022, 11:07pm
10
Are your expected dimensions 150x150 mm? If not, what are they? X,Y format please.
Bluesssman
(Gary Martin)
January 16, 2022, 11:13pm
12
One other problem is LightBurn seems to be having a problem finding my laser.
berainlb
(PY)
January 16, 2022, 11:22pm
13
Enter these in console one at a time:
$130=810
$131=460
Rehome and check origin.
Probably a separate issue.
Bluesssman
(Gary Martin)
January 16, 2022, 11:31pm
14
The size change worked very well. You can not be thanked enough for your help!
Bluesssman
(Gary Martin)
January 16, 2022, 11:33pm
15
I have been taking notes on everything you are helping me with!
berainlb
(PY)
January 16, 2022, 11:36pm
16
Uh-oh. Hope I’m not being graded.
bturner
(Brandon Turner)
January 17, 2022, 1:37am
17
Thanks! the reset command fixed the problem of being able to move the laser. However, the marker that normally shows on the grid to show me where the laser is still does not show anymore
berainlb
(PY)
January 17, 2022, 1:46am
18
Can you elaborate please? You never reported back earlier so no context as to where you are or what you’re addressing.
Please include a screenshot.
system
(system)
Closed
February 16, 2022, 1:46am
19
