Alarm 2 & GPIO isr service is not installed,
I recently tried my rotary tool on my creality falcon laser 10W, which was unsuccessful. I have now disconnected the rotary and want to go back to laser cutting. It will home itself when I turn the laser on. When I load a project I am getting this message in the console. I am a beginner with the laser and have no idea where to start
e[0;32mI (1317) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (1422) serial: Line state changed! dtr:0, rst:0e[0m
[VER:CV-30.V3.0.24.20221012]
e[0;32mI (2488) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0m
e[0;31mE (2511) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).e[0m
e[0;32mI (2512) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0m
e[0;31mE (2514) sdmmcfs: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.e[0m
e[0;31mE (2515) sdmmcfs: TF mount failed
e[0m
e[0;32mI (2516) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
e[0;32mI (2517) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
e[0;32mI (2518) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
[MSG:Axis count 2]
e[0;31mE (2629) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2630) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2631) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2633) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
e[0;31mE (2636) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2638) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2639) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2640) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
Grbl 1.3a [‘$’ for help]
e[0;32mI (2667) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
ok
ok
ok
Homing
e[0;31mE (3937) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (3938) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (4584) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (4585) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (4587) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (4588) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
Project loaded in 8 milliseconds
<Idle|MPos:3.000,3.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 3:
Stream completed in 0:00
[MSG:Reset to continue]
ALARM:2
Waiting for connection…
Port failed to open - already in use?
