Alarm 2 issue and 4 days in trying to figure it out
My Otur Lasermaster 2 will run but if I try to do any work it will not do anything except power up and Home. This Is what I get, Starting stream
Layer C01
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 4: Any help would be appreciated. Thanks
Thought I should add this $$
$0=5.0
$1=100
$2=0
$3=0
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=3
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=425.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.537
$101=80.537
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=430.000
$132=100.000
$259=0
$260=70
$261=70
$262=0
$263=30
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
A few questions:
  1. Is your machine homing properly?
  2. What “Start From” mode are you using?
  3. Can you run these commands in Console and return output?
$H
$I
Note that the first command will home the laser to be prepared for it.
yes I will
ok
$H
ok
$I
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 S0]
[OLF: 185]
[OLH: OLM_ESP_PRO_V1.2]
[OLM: GENERAL]
[DATE:22:22:08 - Oct 25 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMSL,35,4096,3]
Target buffer size found
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[HOME:-397.000,-427.000,0.000:3]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|MPos:-396.998,-426.997,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|VA:12093,1396|A:S|H:0>
ok
This is the likely source of your issue. There is an unwanted offset being configured.
You may be able to recover this by resetting your configuration.
Run this in Console:
$RST=*
That should resolve the issue but I’ve seen cases where for some reason the reset fails.
In either case, after attempting to reset I suggest you update to the latest firmware as Ortur has fixed the issue that causes this unexpected offset to be configured.
It worked thank you. can I
get the update at OTUR?
Yes. Although your specific model is slightly unusual so not sure which firmware it would be.
Not sure if the S0 model is the same as S2.
@OrturTech may be able to provide some insight.
Firmware found here:
https://ortur.tech/latest-firmware/
Try this for me
a) In console type
$RST=*
press enter
B) home machine
Once done, copy/paste full content of console
c) Open yoru project, post full screenshot of your lightburn showing specially laser pannel
