ALARM 3 everytime now
Never problem. I just installed the 120 degree camera and all calibrated good…(Ithink)
While burning a small image approx 2 inch square. Update overlay, open image and move to my wood work piece.
First 3 tries I get Alarm 3 about half way through the burn.
Close program and reboot PC, try again…reset again about 1/10 way into the burn.
USBCOM port speed is at 9600, reset it tp 115000, same problem, so I put COM port back to 9600 and got the last result.
Grbl 1.1h [’$’ for help]
Project loaded in 229 milliseconds
Starting stream
Stream completed in 0:00
Starting stream
Layer C00
Stream completed in 0:04
ok
ok
ALARM:3
ok
[MSG:’$H’|’X' to unlock] [MSG:Caution: Unlocked] ok Starting stream Layer C00 Stream completed in 1:41 Port opened, waiting for response. Grbl 1.1h ['’ for help]
Before camera, never experienced this, maybe not related either.
Now not sure hat to do.
Alex
Just did another same image run
Waiting for connection…
Grbl 1.1h [’' for help] Waiting for connection... Waiting for connection... Port opened, waiting for response. Grbl 1.1h ['’ for help]
Starting stream
Starting stream
Layer C00
ok
ok
ALARM:3
ok
Grbl 1.1h [’' for help] Waiting for connection... Waiting for connection... Port opened, waiting for response. Waiting for connection... Waiting for connection... Port opened, waiting for response. Grbl 1.1h ['’ for help]
Starting stream
Layer C00
Stream completed in 6:41
Stopped about same half way again and cant move anymore. Need to power down or disconnect usb whic restored connection.
I believe now it is a bad control board. Changed to a different board and no more long stationary 5 second burn on connect, disconnect and fail Alarm 3.
Keeping an eye on it to make sure the new (better) control board.
