Reinicie mientras está en movimiento. Grbl no puede garantizar la posición. Es probable que se pierdan pasos. Se recomienda volver a determinar el autoguiado
these are my settings:
$0=10
$1=25
$2=0
$3=4
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$41=0.000
$40=0.000
$100=80.000
$101=80.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=410.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
what do i need to do? what do those numbers represent?
Alarm 3 says you hit either the EStop button or hit a limit switch.
If it is not the EStop button, then look for a short in the limit switch wiring. If you have circuit boards attached to the limit switches, one of those could be bad.
If the sound is like a grinding noise, then something is snagging and stalling out the motor. With the powe off, slowly move the head all over the workarea and watch for tight or snagging cables.
