KarlaaZ
(Karla Zuniga)
1
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Ortur Laser Master 2 Ready!
OLF 140.
Grbl 1.1h [‘$’ for help]
[MSG:Check Limits]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
the laser does not go to homing setting, I don’t. know what to do can anyone help
Is your laser plugged into mains power and do you have a known good power supply?
KarlaaZ
(Karla Zuniga)
3
Yes everything is plugged in. I’ve been trying to fix the position since it’s in the -645 both x axis and y axis
How are you trying to fix the position that it’s causing the homing issue?
Can you run these commands in Console and return results?
system
(system)
Closed
5
