I moved my laser and now I’m getting a homing fail approach alarm. I know the problem is the position X=-1199.99 and Y=-1199.99. How do I reset this to 0,0?
Alarm|MPos:-1199.994,-1199.994,0.000|Bf:15,511|FS:0,0
I have a foxalien reizer laser.
Here’s what I am getting when my laser connects and my settings.
error: Alarm lock
[VER:1.1f.SXDYNZ-V2.1:]
[OPT:VMHL,15,512]
Target buffer size found
ok
Homing
error: Setting disabled
<Alarm|WPos:-1199.994,-1199.994,0.000|FS:0,0>
ok
$0=5 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=2 (dir port invert mask:00000010)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=0 (status report mask:00000000)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=3 (homing dir invert mask:00000011)
$24=250.000 (homing feed, mm/min)
$25=2000.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=2.000 (homing pull-off, mm)
$30=1000 (spindle max rpm)
$31=0 (spindle min rpm)
$32=1 (laser mode, bool)
$100=160.000 (x, step/mm)
$101=160.000 (y, step/mm)
$102=160.000 (z, step/mm)
$110=20000.000 (x max rate, mm/min)
$111=20000.000 (y max rate, mm/min)
$112=20000.000 (z max rate, mm/min)
$120=300.000 (x accel, mm/sec^2)
$121=300.000 (y accel, mm/sec^2)
$122=300.000 (z accel, mm/sec^2)
$130=800.000 (x max travel, mm)
$131=400.000 (y max travel, mm)
$132=100.000 (z max travel, mm)
ok
Because homing is disabled in the machine configuration, the controller will not automagically home.
Set $22=1
and the situation may improve.
Then try the G10 thing. My apology for not spotting the Home Fail message.
It now moves when I click Home, but still slams into the stop trying to get to -1199,-1199. Now here are my settings and what I see when I click Go at Move to Position 50,50 in the Move menu.
$22=1 (homing cycle, bool)
$130=400.000 (x max travel, mm)
ok
Starting stream
error: Alarm lock
On or near line 0:
Stream completed in 0:00
error: Alarm lock
error: Alarm lock
error: Alarm lock
error: Alarm lock
