Alarm sounding when I use the frame function
Hello Folks,
I have the X Tool D1 Pro
I had a connection disconnect on me. I was able to reconnect it, but now a get an alarm when I try to frame my project. I am able to home the laser so the X and Y axis are working and not binding, just getting the alarm when I use the frame function. This is the message I’m getting:
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
Nearing Christmas and at my busiest time. Any help is appreciated.
Thanks
Keith
Hi keith
Are you using ‘Absolute-Coordinates’, that’s in Laser pannel window (in my LB version).
yes, I was shifting it around, and a small plastic U shaped clip popped off. I took a closer look and it was the channel that the arm on the gantry passes between to activate the limit switch. I super glued in on hoping it would be fixed, but no luck.
Thanks
Probably replaceable as a spare part?
