I’m using an older copy of the alignment image that I ran on 0.9.24 and trying to re-align. When I do that and then update the overlay, it’s zoomed onto the alignment image, and overlay work images are nowhere in the park of correct for the bed.
I considered re-running it, but the docs say that you need “at least a 200mm x 200mm sheet” to burn the alignment image on. However, on my 1300x900mm machine, the Frame box for the alignment image runs nearly the full bed. Is this a doc bug? Has the behavior changed significantly from prior versions?
