Hello,
I like to use an camera in LB but the Onefinity is not directly connected to LB
For lasering i can use the “Save G code”.
Can i export G code for the aligning page?
Regards Johan
Hello,
Regards Johan
There isn’t a way to do this at this time, however, the camera markers job is just four corners in a 180mm square, in the middle of the workspace. If you create a perfect square of 180mm, center it in the middle of the page (select it and press ‘P’) you can use the corners as the target marks. If you need to make it larger to improve the accuracy, scale it up by some percentage, like 200%, then enter that scale factor in the camera alignment wizard before you advance to the capture page.
