Alignment Issues between cutting and engraving
Recently, when I try to engrave using my Xtool D1 pro, the engraving is way off. When I frame the job, everything looks fine. But once I start to engrave, the laser moves roughly 1.5 inches to the left. This has happened consistently over the last month. I’ve managed the engraving by manually adjusting the starting point of the laser.
Today, I tried to cut and engrave a Christmas ornament. The cut worked perfectly, correct location. But when the laser started to engrave, it once again moved to the left to the point it set off the limit alarm.
When I try these things using XCS, there are no alignment issues. I have deleted and reinstalled Lightburn thinking something may have happened when I moved to a new laptop.
This is beyond frustrating. Any suggestions???
I’ve seen a number of similar issues on this forum recently.
Go to Edit->Device Settings and review the Scanning Offset Adjustment area. Look at the Initial Offset values. If they are anything other than 0s then redo them with 0s for Initial Offset.
This should resolve the issue.
@Rick Could this be a systematic issue with how devices are being converted in a recent upgrade?
That did it. Thanks for the help.
That’s great. Glad it worked.
@LightBurn Is this a known issue? I’m curious why we’re seeing this so frequently. I’ve only seen this in xTool machines configured as GRBL but not sure if it’s limited to those.
It’s not an issue to my knowledge, no.
