I’m not sure where to post this but here goes. I have an Ultrabot U20 20w laser. Everything was working fine until today. I used it yesterday to make a slate project and didn’t have any trouble. I tried to do another slate project today and things went sideways. I centered the laser on the slate, which is the same thickness as yesterday’s piece and even reset the height. I tried moving it a little to get it better centered when all of a sudden the whole thing started chattering loudly and moving in a jerking motion. I hit the kill switch, shut it off and turned it back on. It didn’t want to home at all and I had to manually push the gantry to the home position. When I told it to home again I started getting Error 8 and Error 9 messages. I checked the wiring and everything looks OK. I tried changing the setting for $27 to 1.5 and 2. Still no luck. I get movement on the Y access when I tell it to move but nothing on the X axis. I bumped $27 up to 5 and it showed up in red on the console. Shut everything down again including restarting my computer and nothing changes. Ultrabot provided zero information for an owner’s manual so I don’t know if it’s a software problem or hardware problem. Is there any command to reset everything back to factory defaults? Any help would be greatly appreciated!!! Here’s what my console screen is showing:
[V4.00(8M.H35.20230313)]
[VER:1.1h.2023031301:]
[OPT:VMPH,63,256]
Target buffer size found
[MSG:Using machine:MKS DLC32]
[MSG:Mode=AP:SSDI=MKS_DLC16487:IP=192.168.4.1:MAC=72-04-1D-AF-67-40]
ok
Homing
ALARM:8
Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.
ok
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
ALARM:8
ok
ok
<Idle|MPos:1.000,1.000,0.000|WPos:1.000,1.000,0.000|FS:0,0|Pn:PXY|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
ALARM:1
On or near line 0:
Stream completed in 0:00
<Alarm|MPos:3.970,1.000,0.000|WPos:3.970,1.000,0.000|FS:0,0|Pn:PY|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
<Idle|MPos:28.970,1.000,0.000|WPos:28.970,1.000,0.000|FS:0,0|Pn:PY|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
<Idle|MPos:28.970,26.000,0.000|WPos:28.970,26.000,0.000|FS:0,0|Pn:PY|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
<Idle|MPos:3.970,26.000,0.000|WPos:3.970,26.000,0.000|FS:0,0|Pn:PY|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
ok
Starting stream
[MSG:Program End]
ok
Starting stream
[MSG:Program End]
ALARM:8
ok
ok
[HLP:$$ $+ $# $S $L $G $I $N $x=val $Nx=line $J=line $SLP $C $X $H $F $E=err ~ ! ? ctrl-x]
ok
